Question about Sony BRAVIA KDL-55BX520 55" Class 1080p LCD HDTV
Sony Bravia KDL-55BX520 HDMI ports won't work but the A/Vports t
HDMI ports will not work but the A/V #2 will. When on Both HDMI ports a message in bottom right corner will say something about no signal an something about the connection. The cords are all good. Is it the circuit board that the ports are all on Bad ??? Need new Board ????
  • Duane C
    Duane C Jul 22, 2015
    I bought a new HDMI Cable and still nothing. There was a recent lightning strike an also knocked out the Modem/Router for the Internet. Sonys website says there is No Firmware Updates for this TV. So maybe its the Board then but there is 5 diff boards in this TV.
    Top Expert:
  • Sony Master
  • 76,171 Answers
Either the HDM firmware or the circuit board will be faulty. Connect it with an other known good HDMI cable, and make sure that the fault is not with the connecting cable.
Posted on Jul 22, 2015
6ya staff
SOURCE:
Sony Bravia KDL-60EX700 BAL Board / Flashing Green Amber
It sounds to be a firmware trouble. Will be best to contact the authorized service center for Sony, rather than trying to do it by yourself, as it is a very skilled work, need both concentration and previous experience. google.com/+GopakumarGopalan
Nov 24, 2013 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
My sony hdtv hdmi broke not working
Either buy a new board or take a HDMI port off of something non working and see if it lines up with the solder points.
Dec 29, 2012 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony KDL-V32XBR2 - no picture, no sound...I'm pretty sure the hdmi input port is damaged...is it worth it to repair/replace? and can I do it myself?
Yes ,you should replace the main board ,because you can'nt repair HDMI interface.
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen
Jan 17, 2012 | Sony BRAVIA KDL-V32XBR2 32 in. HDTV LCD
I'm trying to use my bravia as a computer monitor.
Your Bravia should have a 15 pin PC input, this input can take most standard PC resolutions, however if you a have a video card with an HDMI port, you should set your resolution to 1920 x 1080 @ 60Hz refresh rate so that the signal can be recognized and processed, many standard PC video resolutions are not compatible with the HDMI inputs. You should not require audio cables unless you are using a DVI to HDMI connection.
Crampy
Dec 11, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
How do I connect my laptop to a Sony Bravia model KDL-40S4100?
Two options are available to you-
1. Through VGA Cable(Same cable which goes from CPU to PC Monitor)- For Video.
Take to PC Mode from MENU -> EXTERNAL I/P -> PC.
2. Through HDMI Cable.
Take to HDMI Mode from MENU -> EXTERNAL I/P -> HDMI.
If Still No Video
CASE1- 'NO Signal' Message Comes, then toggle the laptop screen with Function Key (depending upon laptop company).
CASE-2- 'Un-Supported Signal' Message comes then adjust the resolution to 1024*768 or 800*600 or as mentioned in Manual.
Please intimate me if any other problem comes after that.
Jun 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA KDL-55BX520 55" Class 1080p LCD HDTV Logo
306 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
