Question about Philips 42PF9630A 42 in. Plasma Television
What part i.e sound card, circuit board would I need to fix the sound on a Philips plasma tv model #42pf7320a/37?
I posted this question earlier and I am sorry for the repetition but I don't think I was concise enough in describing my issue. The picture on the tv is very sharp and clear but there is no audio; HOWEVER, I do hear white noise..low hum with a shishing sound similar to what you would hear if your TV has that grainy black and white snow like when a tv or radio station goes off air. I cannot control the volume of the sound and there are no volume bars appearing on the screen but I can mute the sound. Also I have tried connecting and reconnecting the cable , dvd player and other devices in different ports so I am guessing something internal is the issue. I am pretty handy and can probably fix it myself if I knew what parts I might possibly need. Any assistance would be greatly appreciated. Thanks.
    Top Expert:
  • Philips Master
  • 76,204 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jul 23, 2015
6ya staff
SOURCE:
Anonymous
  • 93 Answers
SOURCE: Philips 32TA2800
The Way Im understanding your problem is,
it seems like you need to hook your rcas directly to the tv and switch the surround to aux or something similar to that.
Posted on Jun 14, 2009
Anonymous
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
CAYPIANAN
ESTEBAN MERINO
  • 227 Answers
SOURCE: Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Posted on Jul 29, 2009
robo_geek
  • 128 Answers
SOURCE: No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Posted on Oct 07, 2009
Anonymous
  • 30 Answers
SOURCE: screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Posted on Oct 11, 2009
I have Philips Flat Tv model # 42pf7320a/37 ..I have a clear picture but no audio, just white noise and static.
Clear picture but white noise and static?!!!!!. What do you say?. Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 23, 2015 | Philips 42PF9630A 42 in. Plasma Television
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Screen displays bottom half of picture only
This is a Y sustain board and/or buffer problem. Suggest replacing both. Post the model number and I can track down parts for you if you want to DIY.
May 17, 2009 | Philips Televison & Video
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
REPAIR NEEDED
sounds like the Y boards.best to replace all 3 at same time main and buffer upper and lower
http://www.shopjimmy.com/searchparts.cfm?make=Philips
Jul 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
PHILIPS PALSMA TV SSB BOARD
I was unable to locate the part number 310432838731. The SSB board for model 42PF7320A is located below.
Philips 42PF7320A Replacement Small Signal Board
Apr 14, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
