How to tighten or change the belt on my 5kg hoover washing machine.I recently had the a new pump installed and the machine doesn't have the same agitation and not washing the clothes as good. The spin cycle seems to have slowed a bit. I have checked the belt which seems fine but it is a little loose. please help i want clean clothes....
It's always the best idea to purchase a replacement belt as the old one is bound to come off for the same reason as it did the first time ;-0)
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
I would definitely change the pump motor judging from your clear symptoms and observations!
It's probable that the motor isn't running efficiently, just enough when helped by the 'gravity' of the full drum but struggles once that is minimum.
have you done a clean ,hoover have this built in you need to do every so often the filter could be clogged do a clean don't put anything in when your doing this ,how old is it
Disconnect battery earth lead. Do not turn crankshaft or camshaft whn timing beld removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of rotation (unless otherwise stated) Do not turn engine via camshaft or other sprockets. Observe all tightening torques. Remove engine, remve RH engine mounting. Remove auxiliary drive belts, water pump pulley, crankshaft pulley, timing belt upper cover, timing belt lower cover. Turn crankshaft clockwise to TDC on No. 1 cylinder, slacken tensioner bolts 5 & 6. Move tensioner away from belt and lightly tighten bolts. Remove timing belt. Remove water pump and replace with new one. Suggest to replace cambelt as well.
Installation
Ensure timing marks aligned3 & 4. Fit timing belt in anti-clockwise direction, standing at crankshaft sprocket. Ensure belt is taut between sprockets on non-tensioned side. Slacken tensioner bolt 5. slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner bolt 6. Tighten tensioner bolt 5. Turn crankshaft on turn clockwise. Ensure crankshaft sprocket timing marks aligned 4.
Slacken tensioner bolt 5. Slacken tensioner bolt 6. Allow tensioner to operate. Tighten tensioner 6. Tighten torque: 20 - 26 Nm. Tighten tensioner bolt 5. tighten torque: 20 - 26 Nm. Apply thumb pressure to belt at middle. Approximately 5kg. Belt should deflect to 1/4 of tensioner bolt head width 7. Belt tention can also be set using burroghs (BT-33-73F) tension gauge 10 at middle. Turn crankshaft 90 ° anti clockwise. Check belt tension is 9.5 16,5kg (engine must be cold). Install components in reverse order of removal. Fit cranckshaft pully. Tighten crankshaft pully bolts 8. G4-J: Tightening torque: 12-15Nm.
G4-N/G4-k: Tightening torque: 10-12Nm
G4EA: Tighten crankshaft pully bolt 9. Tighten torque: 140-150Nm.
yes there is and its quite simple.num1take a good look and find the two pullys that are most apart pull the moter out towards the front of the machine ,before you tighten make sure the tention is no more than 14 ml.tighten .problem solved.adrian
Hi.
The door will not normally open if there is water left in the m.c. check pump, and make sure the belt is o/k, as some hoovers do not let you open the door if the belt has come off. Please leave feedback.
Thanks.
hi
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt: Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt. Step 2: Remove the old belt and stretch a new one into place on the pulleys. Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell. Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
sounds like a spring which keeps the tub centred is broken. Could also be a worn bearing. this needs specialised tools to get the problem fixed, especially to replace the bearing. contact a repair-person.
