I HAVE A GE UNIVERSAL REMOTE AND A MEMOREX TV AND LOST THE DIRECTIONS TO PROGRAM AND NEED CODE?? PLEASE HELP??
Unfortunately, Memorex TVs can't be controlled by universal remotes. So, there is no code available. If you'd like confirmation of this call Memorex tech support at 800-919-3647.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
I work for Memorex tech support, and to my knowledge there is no universal remote on the market that will control a Memorex TV. They haven't started a dialog with the manufacturers of universal remotes to get the process started, so. . . You have to use the original remote or a replacement from the manufacturer.
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: Direct Entry Code for GE television for GE RM24911 Universal Remote
this is the site for ge codes
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
