You probably need to plug in an OBD (on board diagnostics) tool to clear the warning light. These are relatively cheap for a basic one, less than £20. All cars made in the last 20 years or so have an OBD socket to connect with. Follow simple instructions to clear codes.
the maintence reminder lamp means you are due for oil and filter change.to reset maintence light, turn the ignition switch to the on position engine off.push the reset button on clock control panel for 3 seconds,then turn off ignition switch.then turn back on the ignition switch the maintenance light should be off is so.it has reset.
Maintenance Kit - Contains: Fuser, Transfer Roller, Paper Feed Rollers & Separation Pads , etc
look at below picture, kit available with instruction manual etc its easy to replace. or you can give it to the service center.
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
The message indicates its time to clean/change the drum or other items inside the printer. You can purchase a maintenace kit online or take it in for service. You can also clear this message if you don't want to service your printer ... follow these steps: ***Keep in mind not doing the maintence may cause expensive issues down the road***
1. Shut the Printer off. (Use the shut off switch)
2. Hold down the Left Side of the ITEM and VALUE Buttons while powering the Printer back on.
3. Continue to hold Buttons until the Printer says “RESET MAINTENANCE COUNTER”, Then release the Buttons.
You need to have the fuser replaced, it comes out easy on these back cover just pulls off, and there is two tabs or long silver screws to undo fuser, remove it anf you will see that upper roller is worn, buy a maintence kit for this model which includes fuser and fit it yourself easy done instructions are included with kit.
