My Hoover HCA 36FT ALU keeps building up a thick sheet of ice on floor inside which I have to chip away with a plastic scraper. Fridge also builds up thick ice on back wall inside. Any suggestions?
Thanks. It is about 7 years old now. Door seal on fridge is not sealing. Already replaced seal on freezer door which was a pig of a job. Time for a new one methinks!Thanks. It is about 7 years old now. Door seal on fridge is not sealing. Already replaced seal on freezer door which was a pig of a job. Time for a new one methinks!
If there is ice buildup on a new fridge, most probably the door hinges are not properly installed, and air is getting into the fridge, and the water is condensing out of the air,.If there is ice buildup on a new fridge, most probably the door hinges are not properly installed, and air is getting into the fridge, and the water is condensing out of the air,.
There could also be shipping damage, and the door can not seal properly because something is warped.There could also be shipping damage, and the door can not seal properly because something is warped.
You can't post conmments that contain an email address.
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
you have a blocked drain in the freezer,when the machine goes into defrost the heater comes on and melts the frost off of the evaporator coil,the water melts and goes down the drain hose under the coil and leaks down to a drip pan near the compressor where it evaporates from the heat,your drain is blocked and the water is leaking onto the freezer floor and will drip out onto the floor,i use a steemer to blow out the drain line,shut down the machine or unplug it,melt out all the ice with hair dryer,depending on your model you might have to remove the back inside wall of the freezer to get at drain hole,you need something to push the **** out the drain hose,you can try a turkey baster or air from a compressor or a shop vac set it to blow,when you think it's clear pour a cup of hot water into the drain,if it drains down you're done if not keep hitting it with heat and air to push it through.
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Poor cooling is often the result of a heavy frost build-up
on the evaporator coils. You can't see these coils without removing a panel on
the inside of your freezer. A sure sign that there is a build-up is the presence
of any frost or ice build-up on the inside walls, floor, or ceiling of the
freezer. Such a frost build-up usually indicates a problem in the
self-defrosting system or damaged door gaskets.The refrigerator is supposed to self-defrost approximately
four times in every 24 hour period. If one of the components in the
self-defrosting system fails, the refrigerator continues to try to cool.
Eventually, though, so much frost builds up on the evaporator coils that the
circulating fan can't draw air over the coils. There may still be a small amount
of cooling because the coils are icy, but with no air flow over the coils,
cooling in the refrigerator compartment is quite limited.Here's an inexpensive, though inconvenient, way to determine
if the problem is with the self-defrosting system. Remove all of the perishable
food from the refrigerator and freezer, turn the thermostat in the refrigerator
to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several
towels ready in case the melting frost and ice causes the drip pan to overflow).
This allows the refrigerator to defrost "manually." When the frost and ice
build-up has completely melted away, turn the thermostat back to a normal
setting. If the refrigerator then cools properly, it indicates a problem with
one of three components in the self-defrosting system:The defrost timerThe defrost thermostat (also called the bi-metal switch)The defrost heaterIf it still does not cool properly, there may be a problem
with the refrigerant level or the compressor. You may need to consult with a
qualified appliance repair technician to further diagnose the problem
Check to see if after clearing out the ice sheet, that the gasket for the door is tight against the freezer. If air is leaking by the gasket, it will build up really quick.
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
There is probably an ice build up behind the plastic rear panel. The ice build up gets so thick that eventually, it obstructs the fan and then you get that loud noise as the tips of the fan are chipping away at the ice.
What you need to do is to remove the rear panel and thaw the ice build up. To remove the rear panel is usually only 2 screws at the bottom.....you will find that the panel is difficult to remove due to ice build up behind it, so gentle heat from a hairdryer is a good way to accelerate the thawing process....once the panel is removed, you will see the ice build up......mine was about 2 inches thick!!!
I used the hairdryer to thaw it all out and then once cleared, switched it back on and have never had a problem since.
By the way, my F?F is a Beko CDA563FS......the one with the water dispenser on the front and frost free.
Hope this helps
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
hi mine was doing the same we recently movedhouse you need to turn the legs in front underneath so the fridge freezer is slanting so that when you open the door it will shut on its own now i have no water or ice build up on the bottom hope this helps.
