LE code mean suds have built up. Using non he (High Efficiency) detergent or too much detergent will cause this error most front loaders use he detergent only there is a he swirl on the container
Let your washer sit idle or 45 minutes.Unplg washer as well
Plug in and turn on as left spin speed select no spin press Start/pause to start a drain only cycle. When cycle is complete remove load. Start a rinse•spin cycle to clean out residue.
If the sud were too much you may have to repeat
I am getting the IE not LE
Do you have well water or city water
City water, cleaned all screens and filter for pump. I have ran it in QC mode and all functions seem to work in it. I have had it unplugged for an hour or so now. Will try again soon.
Clean the soap drawer gunk can build up inside the is a releaseblever on the soap side the drawer should slde out
SOURCE: spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the
second to last rinse cycle and that most all rinse cycles are in cold
water. Is your cold water valve screen plugged causing your washer to
rinse poorly? Are you using the HE detergent? If not maybe the
washer is sudsing up to much and having a hard time rinsing all the
suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting
does it take a long time to fill the washer up? Also when it is full
and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of
the washer it might have a hard time draining out all of the soap
water before the next load
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
SOURCE: TROMM WASHER WM2277HW LG. GET IE ERROR AT BEGINNING OF WASH CYCLE
That noise means it is blocked. Did you get the filters in the back of the machine at the inlets? I've been through heck with this.... check out what finally worked.
IE= Inlet Error. I have struggled with this problem. After much trial and error it appears that it is due to my well water. People who have city water will probably not have this problem with this machine. Well water or hard water buyers beware. This machine is VERY much a primadonna princess capable of stopping your rinse cycle at the slightest imperfections. This is the Princess and the Pea of Washers... but I have a series of possible solutions that will have you appreciating her primadonna superiority once again.
Troubleshooting... Listen.... Does she sound like she is struggling and no water is coming in? If so then it isn't. The cycles will last forever as she makes all sorts of grunting noises. Something is preventing the water from coming in. It could also be that the pressure in to the washer is under 55 psi.
a. I have adjusted the pressure in the pumphouse to allow for minor fluctuations so that the machine will have at least 55 psi.
b. Take off the hot and cold inlet hose and clean the screen at the back of the washer. The two screens are supposed to come out of the male receptacles. They are fragile... beware. I use a squirt bottle/atomizer to clean these screens as mine chipped and will not budge.
c. You can add a screen just off the faucets so that you don't have to move the machine each and every time you get an IE error. This helps but does not solve.
d. I installed a faucet filter that I bought from Home Depot in the PVC sprinkler's section. They are made of a black plastic material and can easily cross thread, so be careful. They look about the size of a one liter container and unscrew midway to reveal a removable cylindrical mesh filter. This makes it possible to widen the surface area where tiny particles can be trapped without totally blocking flow to the inlet sensor. :-) When installing this make sure to completely rinse the hoses, and all screens coming into the machine. I took the shortcut first and thought my idea had failed only to discover that the screen behind the washer was partially blocked.
e. Periodically remove the filter and clean. Depending on the quality of your water, you may need to do this at all the points that have a screen.
I now have a screen washer between the sprinkler system filter and hose and the one that comes installed inside the male ends of the inlets for the water hoses. This has helped enormously.
f. Another possible offender is the soap and softener dispenser. To remove and clean press down on the plastic toggle piece on the soap side, the whole drawer should slide off and clean. Non-HE detergents and softeners can create a buildup of gooey gunk. Just clean it. Inside the drawer space you can clean to increase flow. I use baby wipes.
g. Make sure that the filter on the bottom is free from obstructions. If there is water in the drum, you will be flooded if you remove. This is a last resort after all the inlet lines have been cleaned and cleared.
Note: It doesn't take much to lower the flow of water to the point that this machine will not run. Since you cannot override the computer on it to run a spin cycle or even advance to remove water it can be highly frustrating. I've learned to obey my machine and just clear every last possible inlet.
Best of luck.
SOURCE: i have a problem with my LG Tromm front load
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
SOURCE: lg wm-2277hw front load washer getting a OE error
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
Here are some troubleshooting steps for the filling problem:
Make sure hot any cold water are both open the hose maybe clogged or pinched
Both are on, removed at the washer and tested lines, good flow coming out, washer is pulled out so they are free hanging,
