Question about Toshiba Satellite® A135-S2266 PC Notebook
I have a toshiba a135. the screen has a red color
I have a toshiba a135. the screen has a red color to it. i replace the power inverter and the lcd screen but nothing changed. I was putting it back togeather and i was moving the lcd screen and the redness went away but i moved it again and it come back
  • sml9811 Jul 12, 2009
    i have replaced the inverter, the cord from the motherboard to the inverter and the screen. What connection might it be? the video card in intergrated on the board. would compnent cleaner help?
  • 818 Answers
You have some kind of intermittent problem with onboard video or video connector, you must replace it.
Sergio
Posted on Jul 12, 2009
    Sergeant:
    Champion:
  • 249 Answers
Circuit problem.
2 Suggested Answers
6ya staff
SOURCE:
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I have a toshiba a135. the screen has a red color
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
My screen on toshiba notebook only show blank screen. The screen is not dark but has light . If i hook an external monitor it show on external but not on the laptop. I have replaced LCD screen but still...
How about the LCD inverter? Did you replace the inverter? It is probably not the actual LCD but just the inverter that needs changing. Give it a go, they are inexpensive, try eBay.
Apr 01, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba a135- screen is temperamental. sometimes it works other times it doesn't. now would that be a problem with the lcd cable or the lcd inverter?
It is often a cracked cable, or a loose cable, the inverter tends to fail quickly either with no warning or flicking, and flickering then failing. Sometimes if the Video card, is in a mini PCI slot it may need to be reseated. Often though it is the LCD itself, as the Driver Row/Column drivers pack up, this is evidenced by lines, dots colors, spreading across and down the rows and columns.
Feb 25, 2010 | Toshiba Satellite A135-S2276 Notebook
I have a toshiba Satellite a135-s2386. It powers on but nothing on the display. I think I need a new motherboard. But am not for sure. What is the part number for this motherboard. any help will be...
Does the laptop appear to boot up but the screen id blank?
Does the hard disk LED light flash?
If so you may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 09, 2009 | Toshiba Satellite A135-S2386 Notebook
I have a toshiba a135. the screen has a red color to it. i replace the power inverter and the lcd screen but nothing changed. I was putting it back togeather and i was moving the lcd screen and the redness...
Check out
www.lcdparts.net
Jul 12, 2009 | Toshiba Satellite® A135-S2266 PC Notebook
Compatible laptop sceens
You won't know until you dismantle and remove both LCD screens.
They could have different video connector and power connector for the inverters.
The best bet is to buy a new LCD screen or if the LCD screen is OK but the backlight CCFL lamp is worn out or the inverter is faulty, then the CCFL lamp or inverter can be replaced fairly cheaply.
Check out LCD Parts for compoments, repair and DIY info. Use this link.
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite A135-S4527 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
http://www.ccfldirect.com/lcdtutorial.html
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Toshiba Satellite® A135-S2266  PC Notebook Logo
610 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
