SOURCE: does it have a USB port to connect a Ruko stick? If not, how can I connect it?
The KDF-42WE655 does not have a USB port. The current Roku sticks plug into the HDMI port on the TV. You will need to use the power adapter that came with the unit. Plug the USB cord (mini or micro USB) into the back (or side) of the Roku Stick and then plug the power adapter into a nearby power outlet. (It's a 5V 1A DC power adapter.) Roku sells this adapter separately on their Accessories page: https://www.roku.com/accessories . It's ~$10. If you have mounted your TV such that the power outlet is hidden behind the TV, you'll get to the outlet or use another nearby outlet. (Make sure to avoid a tripping hazard if you use an extension cord or power strip to increase the number of available outlets.)
I hope this helps.
