One of the four fountains is overshooting the SPA
There should be a valve to adjust the water flow of your waterfall. If you could let us know what hot tub you own we could better advise. Hot tub 101
SOURCE: great lake spa manuel for 1996 spa
Good Luck! : (
What do you need to know?
Chances are you are needing info on control system?
You may have a "Balboa" control system. Find the Code # and then google. You can get information that way.
I presume you are looking for programming info or topside usage info.
If so, you need to know the manufacturer of the control system and get its required numbers and then search that way.
Spa manufacturers all use only a small handful of control system vendors, unless it is made by them specifically then you have a proprietary system. But your spa probably used Balboa, Gecko or HydroQuip?
