Question about Rancilio SILVIA EXPRESSO MACHINE Silvia Home Espresso Machine aka Miss Silvia
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
Model: Miss Silvia F.n. 60025784 About 15 years old
    President:
  • 1,618 Answers
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Posted on Jul 28, 2015
Anonymous
SOURCE:
Pasquini Livia 90 Auto Dose Panel
First, I'm not a Pasquini tech, but I have worked on several similar brands.
* Most Semi-automatic machines will usually have the program button on the same as the stop button. Some will program all the groups at once or can be individually set up for different pours (shots)
* Holding down the program or stop button for 5-10 seconds will activate the program mode. Note that if you don't press any dosing buttons after 5-10 seconds the program mode will revert to normal mode. Some may cancel out the previous dose set up.
* Before starting, determine what you want a shot to look like. 1 oz, 1.5 oz, 2 oz., etc.
* Set up your portafilter with ground coffee. DONOT change the grind size once your satisfied with the QUALITY of pour (don't confuse this with the amount of the dose. This is handled with the programing of dose water.) Water is absorbed by the grounds depending on the grind size and some times the amount. Pods are different from loose ground coffee too.
* Load up portafilter and place measuring cup(s) under spout(s).
* Press program button and hold for 5-10 seconds. The button will light and stay on (some blink).
* Press the dose button for the appropriate portafilter you have mounted. The pasquini requires you to press the stop/program button once you have achived the desired dose. Other brands require the dose button to be press and held down until the amount of dose water is reached. Letting go button logs the amount in but only after pressing the stop button does it set.
* For other brands, you may need to set up all buttons prior to pressing the program/stop button to confirm dosing of all buttons.
* Remember to keep reloading fresh coffee grounds in the portafilter for each adjustment. Used (wet) coffee will throw out the water dose calibration.
Aloha, ukeboy57
PS; I found a good video from Whole Latte Love site:
https://www.youtube.com/watch?v=1NGN55nYBxQ
Mar 11, 2018 | Pasquini Coffee Makers & Espresso Machines
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
Frothing works perfect....water is extracted just fine. BUT when I put coffee in the basket and tamp it down and put it in the machine it just makes noise like it is about to drip and nothing comes out,...
I have a brand new Via that never worked right out of the box. Could barely get any espresso to come through the portafilter. Got a new portafilter and the espresso now flies out of the machine beautifully. Seems they are shipping2_bing.gif units with faulty portafilter. Bad news is a new portafilter is like $65. See if you can get them to give you a new one. I had the same issue as you, very little espessso comes out.
Dec 29, 2009 | Saeco VIA Venezia
Coffee does not flow into shot glasses. water and coffe grounds seap and sprew from around the top ad down the sides
I had a brand new Via Venezia that I could barely get to make espesso, nothing or very little came out. Got a new portafilter and now it work beautifully, espesso flies out of the thing wonderfully. Bad news is a new portafilter is like $65. I can't believe they are shipping these with bad portafilters, but they are.
Dec 26, 2009 | Saeco VIA Venezia
Water sprays out between portafilter and brewhead.
I had the same problem when I started using the Sirena. When I put the portafilter on I was lining it up with the arrow. I found that if I tighten the portafilter on all the way to the right (past the arrow) it works perfect, no water spraying.
Jul 03, 2009 | Saeco Starbucks Sirena Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Espresso machine will not make Espresso.
Try this remove the portafilter and press the brew button, if water comes out of head, machine is fine but the grind or the tamping(packing pressue) used on the coffee is not right. If you are grinding the coffee just before using it, try a coarser setting. If you pre grind at the store then try tamping the coffee lighter.
May 29, 2009 | DeLonghi BAR 14 Espresso Machine
Water not dripping enough
maybe our coffee is to fine of a grind
Apr 24, 2009 | Saeco Classico Espresso Machine
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Coffee not pouring through portafilter
if your grounds are tamped down too tight, the steam can't get through it.
Dec 30, 2008 | Saeco VIA Venezia
Rancilio SILVIA EXPRESSO MACHINE Silvia Home Espresso Machine aka Miss Silvia Logo
103 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Ekse
Marvin
Marvin
markybean
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
