Washing Machines Logo
Posted on Jul 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher @ Paykel GW 712 washing machine error code 49?
GW712 shows an error 49. I swapped the cold water valve to the hot one, as it had never been used connected the cold water wire to the hot side of the valve and it stll came up with error 49. If I press start it shows the lid is locked, but it is not. Do I need a new water valve, or is something else wrong?
fsean Kil
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Jul 28, 2015
fsean Kil
Expert
Level 2:
New Friend:
Answers
111
Questions
0
Helped
29494
Points
286
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
1helpful
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Fisher paykel washer mod.DG273W1 showing code 49
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Washer gw712 diagnostic lights3rd from left and forth from left on and last on right
That is fault code 49
1helpful
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
1helpful
2answers
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
1helpful
Wont fill cold water
l have a fisher paykel machine that wont fill properly on cold water only hot please help moder gw 712
3helpful
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
1helpful
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
I have a fisher and paykel washing machine IW812 and it has error code 49....Can you please advise what the problem is and how to fix it?
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
1helpful
2answers
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
