SOURCE: 91 kx 250 torque values
Engine Top End:
Auto Decompressor Bolt 104 in·lb
Cylinder Head Cover Bolts 87 in·lb
Cylinder Head Bolts: M10 36 S
M6 104 in·lb S
the S in that means the specified pattern ... just like tightening car tire bolts... please note all that it its INCH lbs....
don't know why it says just 36 for the M10 bolts unless they left out inch lbs
Anything else let me know as i've got a manual for the 250 f... actually i've got a few different ones
Robert
Please take a moment to rate this solution as i've taken a few minutes to find the manual thanks
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
Short Bolts:
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
SOURCE: need torque specs for 98 yz 250,rebuilding engine
Go to the site below and you can download a free srevice manual for your bike.
http://www.carlsalter.com/motorcycle-manuals.asp
Top rating due on this answer!
SOURCE: im rebuilding my warrior
if your using the old bolts, 35 ft/lbs. if new bolts, 25 ft/lbs. that will work just fine.
