SOURCE: bought 8gb memory card - error message
Hi, I suspect that the SD card is to big for that camera as that camera is a lower end camera. You should try the SD card in a camera that is known to be able to handle such a huge card.
SOURCE: Lumix DMC-LC33 shows memory card error -format
This normally happens when the memory card gets corrupt. Hope you have pressed OK after selecting YES. Check whether the card is locked. SD card has a small Lock button on the top left. If this fails, buy a new SD card and format it in the camera before taking any image.
SOURCE: format sdhc card on lumix dmc-fz35
Go into the camera menu and find "format"...follow the on-screen instructions. This will erase the card so download any pics from it first.
SOURCE: I bought a new sd memory card for my panasonic
If the card you purchased is 4 gb or higher it might be SDHC and not regular SD. Check to see if the card you have is 4 gb or higher and check to see if your camera supports hc "high opacity " sd cards. If your camera does you might want to make sure the card bay is free of any dust or other obstructions If nothing works with the new card alone it may be a defective card.
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
