if you printing is just faint, need to replace toner, but if your printing is faint and blurry, need to add grease to the fuser film roller, need advanced skills for that, disassemble the fuser unit take out the fuser film and put some special high temp grease on the heating element, assembly all back and install, the other way is replacing the fuser unit
try adjust the toner aditiute by going in to the printer properties. adjust to 3 if posible and do a test print. If the print out is still faint. try update the firmware of your printer by going to www.samsung.com
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
