Irulu 10.1 inch Android Tablet PC, 4.2 Jelly Bean OS, Dual Core, Allwinner A20 CPU, Dual Cameras, 5 Point Capacitive Touch Screen, 8GB Storage, White Color Logo
Mary Jo Parkolay Posted on Aug 01, 2015
The text size is too large for the screen and I cannot reset it. Cannot change text size from 300%. When reset, does not hold requested 150% size
Theresa Mose
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 10, 2015
Theresa Mose
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
99
Points
My tablet will not come on ADO514UL model number
On a kindle fire 7 can you increase the font size of a downloaded book?
Hi. Yes this is possible. With the page in view double tap on the screen. A menu appears at the top of the screen. Look for the icon Aa. On opening this there is a choice of options e.g. Brightness, text size, colour, font etc. To change the text size tap on the + sign and the text size will increase. To decrease use the - sign. Enjoy your kindle.
How do i find my password for amazon
To request a password reset:
  1. Go to Forgot Your Password.
  2. Follow the on-screen instructions. You may be asked to copy the text from a picture in a text entry box (commonly known as a "CAPTCHA"). ...
  3. Follow the instructions in the e-mail sent to the e-mail address on your account.
Amazon.co.uk Help: Reset Your Password
https://www.amazon.co.uk/gp/help/customer/display.html?nodeId=201168590 How do find my password for amazon Google Search ..goto this link might help you out.
2answers
How do I get Font size larger
Amazon.com: Customer Discussions: Font size changing on Kindle Fire HD
www.amazon.com/forum/kindle?_...1...
Amazon.com, Inc.Dec 6, 2012 - The best Kindle would be the Kindle Fire HDX 8.9 - it has the largest screen and the .... before purchase... does the Kindle Fire 10" have an option for large font? Increasing font size on Kindle ...
Nov 28, 2011
change font size on Kindle Fire
Nov 1, 2011
More results from www.amazon.com
How to reset, when my android zeepad won't work by holding start and volume same time, nor does the reset button do it
Many people say to push and hold down the Volume(+) and Power button at the same time. Push and hold for as long as twenty seconds until you see a green android with green text.
But, on some devices and some Android O/S versions it takes pushing and holding the Volume(-) and Power button and holding them both down for twenty seconds or so or until you see the green Android and text screen. This will show the Wipe Data/Factory reset option. Select this option by scrolling using the Volume(+) button and engage using the power button. Some devices give you a second screen with a list of *no no no no no* and one line of Factory Reset. Again, scroll to the Reset option using the Volume(+) option and select it using the power button.
If the above doesn't work, either your battery is dead or your device is dead.
Why will the tablet not move past the initial start up screen?
It could have hardware problems. It could have software problems. To troubleshoot software problems, when on the initial start up screen carefully introduce a paperclip end into the *Reset* button hole until you feel a little click. Your device should then turn off automatically. Some start up again automatically, some don't. Give it a minute or so and it it doesn't start back up by itself. Push and hold the power button as usual.
This should clear up any software problems and this doesn't cause you to lose any data or changes you've made.
Hardware problems such as a memory chip gone bad will not be helped by a Reset Button reset nor will they be helped by a *Factory Reset" which is done by holding down a combination of Volume(-) and Power buttons to get into the Android factory reset options text list. These are drastic and will cause you to lose any and all personal data and changes you've made to the device. A factory reset will put the device back to new condition. But, alas, even a factory reset will not help if you have hardware problems.
3answers
Will not factory reset using power button + volume up button. What do I do?
some devices need you to press power button + both volume up and down.
1helpful
How do i resize the font on my Nook Color Reader?
Steps To Change Font Size On Nook Tablet
Step 1: Chose a book that you would like to read on your Nook.
Step 2: Next, view the Reader Settings
Step 3: Tap the screen to expose the menu, where you will see a "Text" icon.
Step 4: After having clicked on the "Text" icon, you will see that you have the option to change the font size. There will be a letter "A" that will allow you to change the size. Click on the "A" and decide which font is best for you.
Step 5: Touch the main screen to return to your book.
If you still have any kind of problem then you can take nook color support from experts by calling nook help number. You can also navigate to www Nook com for more information.
How do I enlarge my text size on my Kendal Fire tablet
Assuming you are talking about Amazon's Kindle Fire:
Go to the main screen, pull down from the top, in the upper right hand side there is settings, then go to Accessibility, about half way down there is a switch for "Use Large Font Size". That increases the size throughout the whole system.
Or if you are asking about while you are reading an eBook? While in the eBook click the screen to bring out the settings menu, There is a button that says: "Aa - View" Click that, then you can click the Aa with an arrow above it and it will increase the text size for your book (You can also choose a different font which may be easier for you to read too)
When I try regarding my kindle it says I already have an account an I can't remember the password
You will need to go to Amazon.com to reset you account.
  1. Forgot Your Password.
    If you have a problem reading the "CAPTCHA," we'll give you a chance to try again with a different one. If you continue having an issue with the validation screen, contact us.
Reset Your Password
Change text size
There's a button immediately to the right of the space bar marked with a large and a small 'A' - that's what you use for increasing/decreasing font size on the screen
Top Irulu Tablets & eReaders Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Paul Bade
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
