Question about Bushnell Optics
Harbor Master. Where can I get an objective lens?
  • 3,186 Answers
Might want to contact this seller on Amazon. Maybe he has access to the eyepieces.
http://www.amazon.com/Standing-Leather-Harbor-Master-Telescope/dp/B008CUA31Q?SubscriptionId=AKIAIKBZ7IH7LXTW3ARA&&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B008CUA31Q&tag=wwwbookcompar-20&ascsubtag=55ce794f48308e1580fc8321
Posted on Aug 14, 2015
6ya staff
SOURCE:
SOURCE: New bushnell telescope, cant see anything, what am i doing wrong?
Put the lowest power eyepiece in the telescope-- that's the one with the LARGEST number on it.
Go outside and practice focusing on a distant object at least 100 yards away-- turn the focus knob slowly.
Posted on Dec 28, 2008
SOURCE: BUSHNELL DEEP SPACE SERIES 420 X 60 REFRACTOR TELESCOPE MODEL 78
Do not buy either telescope-- both are junk.
Instead buy one of these --
http://www.telescope.com/control/product/~category_id=dobsonians/~pcategory=telescopes/~product_id=09804
http://www.telescope.com/control/product/~category_id=dobsonians/~pcategory=telescopes/~product_id=08942
http://www.telescope.com/control/product/~category_id=refractors/~pcategory=telescopes/~product_id=09794
Posted on May 15, 2009
SOURCE: I need a user manual for a Jason by Bushnell Reflecting Telescope
Here: Find your telescope manual-
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Jul 11, 2009
SOURCE: Completed setup, can't see anything through eyepiece.
I answered your question already-- TURN THE SCOPE around you have it mounted backwards! The eyepiece end is pointed UP. Like the picture above in your question.
Posted on Jan 23, 2010
Steve B
  • 227 Answers
SOURCE: Just bought a Bushnell telescope
This is not a real telescope, it is a toy. You will be lucky to see anything with the 20mm lens only. the rest are junk. The telescope needs to be collimated (see your manual) and the finder aligned with the telescope. Align the finder with the scope during the day, although this model was known for poor mounting on the finderscope and will become un-aligned easily.
Posted on Oct 18, 2010
Drill master, model 93440 battery needed
Your best bet might be to rebuild those NiCd batteries if they cannot be revived. It is possible to revive NiCds by using 2 good batteries or a high power DC source of about 40 Volts. The details for reviving NiCd batteries are all over YouTube. I suggest you watch a few before attempting to do this. Results are mixed. They may come back almost 100% or they may be done for. In that case you will need to rebuild with new cells. Harbor freight tools are throw away tools. They are cheaply made and have poor support.
Feb 17, 2013 | Chicago Electric Drills
How to use meade telescope 60AZ-T ?
The whole unit is a "scope". What you mean is the objective lens to the eyepiece lens. Usually the wide end is pointed at the object or scantily clad person that you wish to view, and your eye is placed near the small diameter lens at the other end. If you have it reversed, it will work as a microscope.
May 06, 2012 | Meade Optics
How do I get motic microscope lens repair? It's an older model-a BA 200. Our lens is a EF Plan 40X objective /0.65 /0.17
You can send the lens to Delta Optical Instruments, Inc.They can determine if your EF Plan 40x objective lens is repairable.The will give you an estimate prior to work or suggest a replacement if it cannot be repaired.email them at:  robin@deltaoi.com
Oct 06, 2010 | Motic DMBA 300 Binocular Microscope
Brakes go to floor, I replaced brake pads, master cylinder and calipers. We have bleed the brakes and bleed the brakes and still pedal goes to the floor.an my anti brake light is on What are we missing?...
Hi chances are the master cylinder still has air in it.If thay put plastic bleeder hoses and fittings in there for you just throw them in the trash.go to your local parts store and buy steel lines to for it,you may need an adapter for one of the ports. and re bench bleed your master cylinder.You could have air traped in the system too.A vacuum pump with a brake bleed kit work's great for this.Thay are 24.99 at harbor freight I just baught one from them.If you don't have a harbor freight in your area,thay are on line at www.harborfreight.com. Hope this helps you.Thank You for using fixya....iluv2fish.......Ray.......
Jul 09, 2010 | 1991 Nissan Pickup
My FUJI FINEPIX S5700 Digital Camera keeps saying
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
May 10, 2010 | Fuji FinePix S5700 Digital Camera
My microscope is focused on an object on the slide but not the object I am to observe. What is the possible problem?
You must move the slide so that the "Sample" is "Under: the object lens...Or move the sample so it is directly under the object lens, the sample must be right in the "Middle" of the "Slide" the sample is on.
Mar 01, 2010 | Science & Laboratory
Jan 22, 2010 | Bushnell Deep Space 78-9003 (525 x 76mm)...
Lens' in my new Voyager 78-9960 telescope fell out
The small squares are spacers between the lens elements. Most objectives have 2 parts, with one lens like() or (|. That is the one on the outside, with the outwardly curved side facing the object to view. The other lens goes behind it, making the stack look like: (object) --- ())| for the 2 lenses. Sorry, this page does not allow proper graphics, but I hope you get the idea.
Do not tighten the retaining ring too tight - just enough to hold in place. The lenses need a little space for thermal expansion.
Oct 17, 2009 | Bushnell SkyTour 78-9960 (700 x 60mm)...
Difference between lens and mirror
a mirror reflects the object in almost same size of actual object.A lens show an object in a large or small size than actual object.
Jul 08, 2009 | Photography
Upside down images
As we all learned in grade school, telescopes produce an upside down image - it's okay for astronomical use since upside down doesn't matter. If you want an image like you'd see in a pair of binoculars, get an image erector from a telescope accessory store to add to your eyepiece.
Aug 01, 2006 | Fieldvision 114mm Reflector (114 x 114mm)...
Optics Logo
266 people viewed this question
Top Bushnell Optics Experts
Ekse
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
