Question about Oxo Good Grips 11-pound Digital Kitchen Scale with Pull-Out Display
Why do the numbers on the oxo digital food scale appear only in half?
Sorry no model number. Batteries have been replaced and numbers only show in half. Please help
    Champion:
  • 203 Answers
Sounds as though the LCD display is faulty and only half is lighting up. I would have thought the cost of replacement is greater than the scales are worth. May be a bad connection that needs resoldering, but usually they are not serviceable.
Posted on Aug 04, 2015
Anonymous
SOURCE:
Digital food scale will not turn
It is possible the replacement batteries could be defective or installed incorrectly.
Sep 11, 2016 | Taylor 3843-49 Digital Food Scale 11 Lb /...
Replaced batteries and scale does not register weight, but just races through numbers and then "Err."
I have same problem with my scale. New batteries work for a few days. I'm throwing this thing out.
Oct 09, 2015 | Homedics SC-405 Glass Digital Scale Silver
My digital gram scale does not work. the screen has some kind of word. Please help
Try recalibrating it by turning it on while holding the "tare" or "mode" button. It should show a raw data from the sensor then. Press the tare button again and it should calibrate the empty weight. Then it will show a specific weight you should put on, usually 100g. It should automatically finish calibration now. Hope this helps. The words before calibration on my scale was OUt2
Sep 24, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Can the display be repaired a on an oxo food scale?
Depends on what the problem is. If it is electrical then yes or if it physically damaged then replacement is necessary
May 03, 2014 | Microwave Ovens
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
My scale just went blamk and wont show numbers even after re callibrating it.
Hello. when the scale goes blank it is time to change the batteries. Turn the scale over and you will see the battery compartment. Take the batteries to Radio Shack or Walmart and get the same in the new ones. Then be sure to install them correctly regarding the polarity [ the + and the -]
please rate my answer as very helpful. thank you.
Mar 26, 2010 | Taylor DIGITAL SCALE BODY FAT WHITE 1.0'...
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Oxo Good Grips 11-pound Digital Kitchen Scale with Pull-Out Display Logo
532 people viewed this question
Top Oxo Good Grips Dishwashers Experts
Marvin
Marvin
Are you an Oxo Good Grips Dishwasher Expert? Answer questions, earn points and help others
