Konica Minolta bizhub C250 All-In-One Laser Printer Logo
g
giano Posted on Aug 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error c204 appeared.Checked for paper behind paper casete I reset error code with no resultI removed second casete but now error c206 appears removed casete 3 and error 208 appers.Any idea?
Error c204 appeared. Checked for paper behind paper casete but there wasn' any. I reset error code with no resultI removed second casete but now error c206 appears removed casete 3 and error 208 appers.Any idea?
Jojo
Level 3:
Master:
  • Konica Minolta Master 478 Answers
  • Posted on Nov 19, 2015
 Jojo
Level 3:
Master:
Answers
478
Questions
12
Helped
79675
Points
1328
1 Related Answer
Anonymous
  • 74 Answers
  • Posted on Mar 31, 2010
SOURCE: Bizhub C10, error c0045
The Fusing Cooling Fan Motor (M3) Lock signal HIGH for a continuous 1 -sec. period while the Fusing Cooling Fan Motor is turning at full speed or decelerated speed. This may need to be replaced or checked by a service tech
Testimonial: "Quick reply and to subject oriented. Bravo Expert!"
1helpful
Error 501, 502, 503 & SC441
Error codes 501, 502, and 503 on a Ricoh MP-8001 indicate a problem with the paper cassettes. SC441 is a drum motor error code. Here are some steps you can take to troubleshoot these issues:
  1. Check the paper cassettes: Make sure that the paper cassettes are properly loaded and that the paper is not jammed. Check that the paper guides are set correctly for the paper size.
  2. Reset the paper cassettes: Open the paper cassettes, remove the paper, and then close the cassettes again. This may reset the paper cassette sensors.
  3. Check the drum motor: SC441 is a drum motor error code. This may indicate a problem with the drum motor or the drum unit itself. Check the drum unit and make sure that it is properly installed.
  4. Check the front door sensor: If the front door open sign is appearing on the screen even though the door is closed, there may be a problem with the front door sensor. Check the sensor and make sure that it is properly installed and functioning correctly.
If these steps do not resolve the issue, it may be best to contact a qualified technician for further assistance. They will have the expertise and equipment necessary to diagnose and repair the problem.
tip
While preparing our families Christmas Eve dinner The dreaded F7 error code...
Do you have the dreaded F7 message pulsating from your oven? The original purpose of the F7 message is to signal a stuck START key, which is a rare occurrence. The more common cause is a type of short circuit that occurs in the touch panel near the cable slot. The fix that I will describe addresses this type of fault. It will not fix a stuck START key. It will not fix a faulty Electronic Range Control (ERC). If you are getting other errors, such as F1, the fix may still do the job. F0 is usually a shorted off key. Cleaning the ribbon cable connector is a myth. What you accomplish is to temporarily disrupt the short circuit occurring near the slot in the touch panel. With time the short circuit grows back. It happens more often when the humidity is high. So here is my solution to the F7 problem. The most important step is first turn off the power to the oven at your circuit breaker panel. You will need to open the touch panel. There are typically three small screws on the bottom edge of the touch panel. It is advisable to have an assistant to hold up the panel while you work on it. Pull the panel outward at the bottom to gain access. There are many wires attached to the panel. Do not allow the panel to dangle by the wires. When the panel is open, you will see a flat ribbon cable connecting the ERC to the touch panel. See photo # 1. The principle of the fix is to apply additional insulation in and around the ribbon cable at the slot where it exits the touch panel. There are three basic styles of touch panels. Here is how the fix is applied for each style. 1. Plastic touch panel with a two-segment ribbon cable. Apply a slip of paper or file card material between the two segments of ribbon cable in the area of the slot. Work the paper down as far as it will penetrate. Typically it will only go in about 1/8?. See photo # 2. 2. Metal touch panel with a two-segment ribbon cable. Apply the extra insulation as per style 1. In addition, apply extra insulation on both sides of the ribbon cable and the edges of the slot. See photos #3 & #4. 3. Metal touch panel with a one-segment ribbon cable. Apply the extra insulation on both sides of the ribbon cable and the edges of the slot. If your style is different from the above three styles, the fix will not work for your situation. Don?t be concerned about using paper for the insulation. It will not get hot enough to burn. You will probably find a set of instructions printed on paper in the top of the oven when you open the touch panel. If the fix doesn?t work for your situation, you will need to replace either the touch panel or the ERC. Here is how to determine which one is faulty. 1. Turn the power off. 2. Remove the ribbon cable connector from the ERC. 3. Turn the power back on. If the F7 does not appear after a few minutes, the problem is in the touch panel and it must be replaced. If the F7 returns after a few minutes, the problem is with the ERC and it must be replaced or repaired. Check www.cgiltd.com for information regarding repairing ERCs. Good Luck. May the ?fix? be with you.
on Dec 26, 2009 • Ovens
Konica minolta c350 error code c204
C 204 Tray 2 feeder up/down abnormality.Check the M9 paper feed tray 2 lift up motor connector for proper connection,the PS15 paper feed tray 2 upper limit sensor actuator,the motor coupling.
Error code C0910
Second Draw lift open the second draw remove the paper from behind the draw, ALSO REMOVE THE PAPER BEING STORED ON LEFT HAND SIDE OF THE DRAW. IT IS NOT A STORAGE AREA!!!!!!! It is available for 11xx17 paper. Storage is for the storage draw!!!!!!, IF not these two items you have a bad motor for the second draw or worse case a bad control board!!!!$$$$$$
try this site for parts:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Hi there...we have an error saying paperjam - code=007. I have checked for paperjams and there doesnt visually appear to be any. What can you suggest?
When you removed paper from the machine, did it rip at all? If it did, a small scrap could have been left behind, causing the jam code. Depending on where the machine is located and who uses it, there might also be a foreign object lodged in it (like a staple or paper clip). If you think there is nothing in there causing the jam, try turning the machine off and turning it back on, and see if it still shows the jam.
2answers
Two copiers. Gestetner DSM618d - Will not stop showing jam indicator in compartment B. Have a code to call service center error - SC571. No idea. Aficia 200 - keeps saying call service center. Ken...
for the jam code make sure after you have checked that you reset the side door correctly on upper and lower section and that the re is no paper caught behind the paper sensor arm as somtimes if pulled down it can tear and jam the sensor..the 200 might just need the pm counter change or reset..go into the service mode via clear[yellow] 107 then hold down the stop button till the creen changes copier sp and then 7. data log and you can reset the pm there...good luck A
11helpful
2answers
Trouble resetting error code on my t-30,error code reads 0176
Error code 0176 concerned with System Security. The system has been tampered with.
Try to enter the bios setup. Save the bios setting and exit. Lets see if it resolves your problem
1helpful
4answers
Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Printer Acting strangely - red led appears after 13 seconds.
If the red error light is on by itself this indicates a Fatal Error: Fatal error indicates one of the following: ? HP sensor lever or PE sensor lever does not move smoothly. ? HP/PE sensor is defective. ? CR motor is defective. ? PF motor is defective. ? Main board is defective. ? Printer Housing is not secured with screw on the printer mechanism. You could try reflashing the firmware which sometimes helps to rectify this error.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
