It will go up and down but will not come off. I have had some strong men try. It was off when I bought it and it works fine but I need to change the apparatus.
Try and get some CRC into the top where the hook joins the shaft. You need to be rocking it back & forth to try and get movement. Gradually the movement will increase if your strong men are strong enough and have stamina as well. Once you get it off clean up the shaft with a wire brush. Clean out the hole in the dough hook with the proper size drill, you don't want to make the hole bigger, just cleaner. It will be a build up of flour in there, it packs hard and shrinks the hole, almost unbelievable but true.
