SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom.
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working.
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
SOURCE: Low water level error with
Do you hear the washer draining (into the sink drain) after it fills and should start washing? Check that nothing (sound deadener, etc.) is interferring with the drain valve lever arm.
SOURCE: i have a samsung dmt300
I would remove and examine the wash arms to see if any of the holes are plugged with food or mineral deposits. Clear any food with a paper clip. If you have mineral deposits, remove the deposits with Lime Away or CLR cleaner. Hope this helps you.
SOURCE: I have a DMT300rfw samsung dishwasher. The other
Hello, jduffy
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
