Seems the door is very cold, is this normal?
SOURCE: upright freezer
just asked a question not needing to pay 10 .00 dollars for the answer can call frigidaire for fee
SOURCE: upright freezer problems
Hi Robert,
Happy to help.
Sounds like it is low on freon
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
SOURCE: Does the light on the outside of freezer stay on
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
SOURCE: I have a Frigidaire upright freezer model#
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
SOURCE: Bought an upright Frigidaire Freezer on Craigslist
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
