The bolt is stripped away from the plastic knob-- TAKE THE vertical lock knob off and inspect the bolt head-- you can use a STRONG glue to fix it -- epoxy or something similar.
The knob had a tiny set screw on the side of it-- that tightened down on the shaft.
See if you can tighten it back up. If it is missing take it to a well stocked hard ware store and see if you can find a replacement Allen style set-screw.
It's a simple solution!
Take the knob off, and use a simple washer, will will hold up in between the plastic and metal surfaces.
This should be your solution!
You did tighten the DEC knob? If you did the altitude gears (a worm gear) is not engaing properly. You can either return it to Meade for repairs or attempt them yourself.
I would also check that you have fresh batteries and that the UP button on the hand controller is not broken.
