Question about LG WM0642H Front Load
Leaking water from front of door. Replaced boot seal but still leaking. It looks like door is kicked out at the bottom. Would replacing the hinges help?
  • LG Master
  • 2,528 Answers
I would say check the hinge mechanism. If it "sticks" it can hold the door slightly ajar
Posted on Jun 28, 2019
    Master:
  • LG Master
  • 330 Answers
Try turning the water pressure down. If you have high water pressure the water comes into the dispenser to hard and splashes over the front & side of the dispenser draw the trickles down the inside of the front panel out on to the floor. Very common front loader problem.
Posted on Sep 30, 2015
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Posted on Jul 25, 2008
Anonymous
  • 236 Answers
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Posted on Mar 16, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Posted on Aug 19, 2009
Linh Thanh
  • 784 Answers
SOURCE: water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Posted on Jan 08, 2010
rockeye007
Rocky Wright
  • 81 Answers
SOURCE: Water Leaks out of bottom of door
the first thing i would try is to loosen the hing screws couple of turns,push in on the bottom hinge and tighten screws.
Posted on Dec 10, 2013
Water leak out the bottom of the door when it running door seam lose
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Manufacturer Part Number 4986ER0004G
Jan 27, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dec 10, 2013 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
How to stop dishwasher from leaking out of the bottom left corner?
follow the next steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenses ed19f28b-0f72-4aa8-a09e-69699854be01.gifgasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 06, 2013 | Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Water is leaking copiously from the bottom front door.I think the seal has broken.How difficult is it to replace.A repair man cannot even look at it until wednesday next week.
Before you replace it try cleaning the bottom of the glass door. Often water deposits and soap build up on the bottom of the glass door and it no longer makes a good seal with the door boot.
Other wise it's not hard to replace the boot, just take a little time as you will have to remove the front of the washer.
Aug 03, 2011 | Dishwashers
Water leaking out of door , seems like it might be a problem with the door hinge ?
Not likely that you have a hinge problem, but it can happen, especially if water has been dribbling down the back side of the front panel from the dispenser area, getting on the hinge, and causing it to bind up. Replacing the hinge is a pain because the screws are put in with thread lock, requiring heating or even drilling in some cases. If you have water dripping down the front of the machine from the door, the most common reason is that there is some lint or hair on the bottom side of the glass door, preventing a complete seal to the gray rubber gasket. Generally, just cleaning off the bottom of the glass door will fix it. If that does not do it, you can try moving the spring clamp (which holds the front of the gray tub seal) from the bottom (6 O'clock position) to the hinge area (9 O'clock position) Sometimes, the leak is caused because someone pushed the washer into place by placing their hands just below the door and actually deformed the metal front panel inward, preventing a seal between the door glass and the gray tub seal. If that is the case, it may be corrected by removing the spring retaining clamp, taking the front of the gray tub seal off, pulling outward a bit on the metal panel at the bottom of the door openings, and replacing the seal and retaining band again.
May 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
WATER COMING OUT FROM DOOR AND DRAWER
On this washer  the seal was replaced ?Did it stop leaking after the seal was put in ? Front load hatch on this is in front area located on the bottom(base).Remove the front  to gain access and you can now reach the pump and  look for any blockage.After  you have found and removed the blockage,run the washer again and if any water leaks remain call your local  servicer .You may have a bad front boot (seal) or its just loosened and it need to be re- tightened.Any water leak should be repaired ASAP so you dont have even more damage to the machine and your home.If the repairman cant stop the leak on his first visit than have the Boot replaced on his second visit.
May 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
LG WM0642H Front Load Logo
684 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
