Nokia N70 Cellular Phone Logo
Simak Prince Posted on Aug 09, 2015
Sir .. This phone got white display ..
This phone got white display ..so i used jumper solution .. sam part i removed , that area 2 part got damaged that 2 parts can't replace 'now not turn on .. see i attached image ............ how fix this .. any way ?? sir send me image step by step
  • Simak Prince
    Simak Prince Aug 09, 2015
    Sir ..Check This
2 Related Answers
Anonymous
  • Posted on Feb 19, 2009
SOURCE: nokia n70 freezing after few minutes
no software instal
Anonymous
  • 60 Answers
  • Posted on Jul 01, 2009
SOURCE: my nokia 7610 display turn to white
change the screen
99helpful
9answers
Karbonn k9 white display
halo sir karbann k9 white display
Hello sir, Nok 7230 display & Patta is changed but display are white
Ok, you have done all the possible components but there are two thing to do now .The patta (strip) connector and the display IC (filter).So, if you want to check it out follow this link NEW GSM SOLUTIONS: Nokia 7230 display jumper ways solution.good luck
2answers
I have changed both the LCD ic and display but my 3110c nokia is showing white display please give me asolution for this
sir plz service your cellphone in the nokia service center they will install any new softwares or they will check the mother boad status of the cell phone...........
1helpful
White display
White lcd for ever or the phone is ok but the lcd is white
Please feed back
8helpful
2answers
How to remove headphone icon from the display
I have encountered with the same problem with my Nokia 6630. This may happen if somehow your phone is damaged by water or your cell is experiancing a extermly humid environment. So do one of the following:
1. Switch off your cell. Remove battery and put it some time in direct sun light. If possible your headset jack facking sun face. You can also use your table lamp. Just bend it to cover phone.
2. You can also use your hair drier. Just blow the hot air towards your phone.
7helpful
3answers
Nokia N72 Display Problem
sir we need n72 display ic jumpers on the board
1helpful
Password software.
hi there, if u want to do this you would have to go to the security section in settings and select the area you have this file and put on a lock with your secirity password on that particular area that u want hidden.To access this file or folder u would have to remember the code u used to lock this particular area. No one else would be able to access it but u once the security code is known only by u. Sam !
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
