The door lock light is on but the door will not open. Need to reset so the light will go off and the door will open
Hello. The door lock switch part number is 34001011 in case yours is defective. Usually, just unplug the unit, wait a few minutes, then plug it back in. The main board will unlock the door. On a front load washer, the easiest way to replace a defective door switch is by removing the spring clamp that holds the bellow onto the front of the unit, pulling the bellow aside nearest the lock and swapping it out. HOWEVER, putting that clamp *back on* can be a real headache--I'm able to replace the clamp by hand on the clamps with the smallest springs. The larger ones will require a threaded clamp spreader tool, available at better(larger) appliance parts dealers. If you are hesitant about attempting this, definitely call for service--if the bellow is re-attached incorrectly, it will leak or can be torn because of wrong positioning which can result in it rubbing against the spinning basket. I hope I helped you!
SOURCE: door is locked and get error code do
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Hello Steven Krenz - Was the unit in self-clean mode? Try pressing and holding the "Clear/Off" button to stop any operation of the EOC. Do this at the same time while pushing and hold the light switch to the left of the door lock. Usually this will trick the oven into unlocking the door. If it is ineffective, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and redo the steps. If door continues to maintain locked while open, the unit may possibly have a faulty door latch or a communication problem with the EOC. Contact a professional to move forward accurately.
