HAVE A HITACHI TV MODLE #57F500 CAN NOT GET THE REMOTE TO CODE SEARCH TO SET UP WITH THE TV CAN NOT GET ANY THING BUT SNOW ON THE SCREEN CAN YOU PLEASE HELP
Codes to check with Hitachi brand TVs are:
0102 0104 0107 0110 0119 0126 0127 0150 0152 0161
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
SOURCE: programing i need a access code, one for all universal remote controll
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4700
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: i need a remote code for a hitachi tv
Here is the setup copde page http://universal.dev.efocus.nl/?pag=54. I didn't see that model remote listed but many times the remote manufacturer will use the same codes.... So look at other remote codes for Hitachi and see which one works.
MM85
SOURCE: Code search for Panasonic Tv on Universal remote
i need code for panasonic tv with zenith remote control
SOURCE: LOST MY INSTRUCTION MANUAL FOR MY RCA DIRECTV UNIVERSAL REMOTE
Here's an on-line guide
Here's a codes page (Sylvania 10054, 10030, 10171,10020, 10096, 10381)
