If you start the car ,leave it in park,push on the brake pedal very gently,
if it slowly fades, the master cyl. is bad.
If not,has to be air,just take the master cyl. cap off,and open a bleeder,let gravity do the rest(rears first) takes awhile but all the air comes out. Pumping the brakes to bleed tends to "whip"air bubbles into the system,
Hi there: DTC P1255 - Pedal Correlation PDS2 and LPDS Low
It's when there is the wrong voltage between the electric throtlle body, and the electric gas padle assemblys. Either there is something wrong with the throttle body electric motor, the gas padle was disconnected, or there might be something else Im overlooking.
You need to be aware that some diagnostic equipment can put out spurious fault codes which are extremely misleading.
brake lockup. due to tight torance from the brake padle to the master boot. loosen the nut on push rod behind the brake padle and decrease the rod travel.
as far as the clutch, you may have the same problem.
do a serach in the Internet for the tolerance. usually is 1/8 to 1/4"
The paddles are the plastic things inside the metal drum. they are held
in by tabs that slide into slots in the drum and a metal tab from the
drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare
part and come with instructions. you will need to varify which version
you have by counting the bumps on the end of the padle, should be 2 or
3.
basically you put a small screwdriver down on of the holes in the top
of the paddle, i think the 3rd one, to push the metal drum tab down
enough to be able to pull the paddle towards you and out of it's slots.
carefull not to push the tab down too far as it will bend inside the
drum and isd pain to bend back again.
Are you pressing down on the brake padle when you are trying to get it out of park? If that don't work check the fuses & there may be a relay that's may be related to a safty divice to the stick shift. If you don't press the brake padle the stick shift will not release so if you leave the car running a child could not push in gear. The lock silinoid is at the gear console
not the right method, the paddles are the plastic things inside the metal drum. they are held in by tabs that slide into slots in the drum and a metal tab from the drum flips over a ledge underneath the paddle.
if its loose you may need to replace it, they are available as a spare part and come with instructions. you will need to varify which version you have by counting the bumps on the end of the padle, should be 2 or 3.
basically you put a small screwdriver down on of the holes in the top of the paddle, i think the 3rd one, to push the metal drum tab down enough to be able to pull the paddle towards you and out of it's slots. carefull not to push the tab down too far as it will bend inside the drum and isd pain to bend back again.
How to fit Washing Machine Drum Paddle Lifter For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter. A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple. The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out. Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines. There are few types of drum lifter; drum Paddle lifters On hotpoint, creda, Ariston ,indersit and someother makes see video To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine. Huge selections of lifters are available on thewebsite DrumPaddle lifters
