Mach Speed Trio Stealth Pro 7 7" 4 GB Slate Tablet - Wi-Fi - ARM Corte Logo
Alero Posted on Aug 11, 2015
How do you unlock a trio stealth pro tablet if it is in safe mode?
Ghost18_07
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 65 Answers
  • Posted on Aug 16, 2015
Ghost18_07
Contributor
Level 1:
Cheetah:
Answers
65
Questions
0
Helped
20469
Points
74
What do you mean with unlock , did you forget your password ?
2 Related Answers
jaffa012001
L Jefferson
  • 376 Answers
  • Posted on Mar 12, 2014
SOURCE: users manual trio stealth pro
Manuals are available from their website at: http://www.triomp3.com/manuals.php
ssandoval83
  • 50 Answers
  • Posted on Oct 29, 2014
SOURCE: How do I appropriately close down my trio stealth G2 10" tablet?
Hold down the power button until you see a menu pop up. Then press shut down / turn off (depending on which version of the software you have)
My tablet wont un lock I put it on voice command nown it wont unlock thanks
You are screwed, unless you know the security code, so take out any memory cards and do a factory reset. You will loose any data but he phone will work again.
2answers
Trio stealth tablet will not go past logo
This may be unrelated, but if you let the tablet go to sleep it will drain the battery. I found this out with my Stealth Pro about three months ago, I imagine it is more of an Android issue. It would not startup or go past the opening logo until I had charged it enough. This may also be the case if the battery is damaged or will not take a charge, in theory.
My trio stealth 10 MST10-21 won't stay turned on
This may not be the problem, but worth checking. I ran into this the other day with my Trio Stealth pro tablet. I had left it on while unplugged and it drained the battery completely in sleep mode. It would only show the startup icon and shut right off. After a complete charge it is back to normal operation. You might try making sure the charge is full, maybe the battery has gone bad and that would also affect operation. Also try starting it up without the SD card in. If it doesn't mount properly or a file is corrupt, it may act strangely. I believe it scans the SD card first and may be trying to startup on it. Other than the above mentioned, it could still be hardware related with Ram or CPU problems. Good luck in finding the problem, tablets can be fun but frustrating sometimes.
Trio Stealth G2 HYpe tablet will not connect to wifi. Had been working but now can't get the wifi to turn on.
I had intermittent trouble with connecting my Trio Stealth Pro 7" tablet to my secure wireless. I have since upgraded my DSL modem / Bridge and have not had an issue since. You should contact your service provider if you have had the same equipment for a number of years.
1helpful
Trio stealth pro wont connect to pc
trio tablet ge wram when chargeing and want power up
Trio Stealth pro 7 inch tablet will not boot up
http://www.slatedroid.com/topic/41611-rooting-procedure-the-trio-stealth-pro-97/
javascript:void(null);
4helpful
Is there an operator's manual for the trio stealth 9.7 tablet?
Hope this helps: Link HERE
I was looking for the same things with little to no help.
4helpful
2answers
How to unlock a trio stealth pro 4.0 0S if forgot pattern lock
i got a trio stealth about a year ago but now my son lock it and cant find a way to unlock it pattern please any one help me with this thank you so much
Top Mach Speed Trio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mach Speed Trio Computer and Internet Expert? Answer questions, earn points and help others
