Question about Maytag MAH2400A Front Load Washer
Need advisement on how to balance washer. It vibrates extremely when in the rinse/spin cycle and is very noisy. I have tried many things.
It was new and given to me by a friend. when moving into my place recently it was partially dropped. Could that cause an issue?
  • Maytag Master
  • 18,127 Answers
There are springs and bumpers that hold the drum in the center and if one of them popped off, that causes this problem. What is the make and model number
Posted on Aug 13, 2015
  • Ima Barnett
    Ima Barnett Aug 13, 2015
    Brad Brown: Maytag Model MDE2400AYW
  • Brad Brown Aug 14, 2015
    That model number is for a dryer.
6ya staff
SOURCE:
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
Ge super capacity plus washer
It sounds like your bearings are are whacked, if you have vertical
movement in the drum the bearings will need replacing , not a simple job as seals also need replacing
Dec 20, 2013 | Washing Machines
VIBRATION DURING RINSE CYCLE. NOISY
The 2 main causes for excessive vibration during rinse or spinout cycles are:
  • Machine is out of balance....The adjustable feet can correct this or over time, it's possible the machine shifted slightly and is no longer level
  • A worn belt whereby the tub wobbles more than it rotates; check for a worn belt.
Mar 24, 2011 | Whirlpool Washing Machines
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
OUt of balance during rinse and spin cycles
I have the same problem. During the spin cycle, the washer spins all over the room.....very loudly.
Dec 26, 2009 | Maytag Washing Machines
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Maytag MAH2400A Front Load Washer Logo
60 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
