A
Anonymous Posted on Aug 14, 2015
What's difference between Sony str d615 an Yamaha rx v459
Larry Stiles
Level 2:
Champion:
  • Expert 301 Answers
  • Posted on Aug 14, 2015
Larry Stiles
Expert
Level 2:
Champion:
Answers
301
Questions
0
Helped
87537
Points
443
You should be able to download the user manuals on both of these units for free by just googling them and then compare the stats.
Larry
3 Related Answers
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: yAMAHA YDS-11 TO A RX-V459
Hi, as per yamaha site RX-V459 doesn't have the DOCK connector which is used by YDS-11 dock (or the bluetooth module). This is the only possibility to connect the YDS-11. YDS nor receiver don't have USB connector and they are not needed.
For example RX-V465 does have DOCK connector and supports YDS-11.
For your receiver, you can use only analog audio cable with your iPod.
Anonymous
  • 8546 Answers
  • Posted on Mar 14, 2011
SOURCE: Can Yamaha RX-V459 setup as bi-wired?
No, why? It's more hype than actual improvement.
http://forums.audioholics.com/forums/archive/index.php/t-1223.html
Testimonial: "Thanks for your quick reply, Guru. :)"
Anonymous
  • 8546 Answers
  • Posted on May 18, 2011
SOURCE: hello i have a yamaha RX-v459,
Yes, the cable box should/could be treated as any other digital audio device. The video could also be run directly to the TV as it doesn't actually improve from being routed to/through the Yamaha, does it?
The labeling on a given input is irrelevant (except for "PHONO", which is literal and exclusively for a turntable).
Testimonial: "Thanks!"
My Yamaha RX-V459 amp will not turn on. Suggestions?
Check the fuse, it's possible to be blown. If you not deal with electronics, don't atempt to repair it ( first you need to know what cause the fuse blown, and after that you can change it) so, i sugest to call a service center.
Yamaha Theatre receiver turns off at high volume 'Check SP wires' checked speaker wires no problem found. Why is this happening?
there are usually 2 things that cause this, (1) a driver in your speaker is going bad or a output IC/transister is going bad. Being a tech I have seen devices that operate fine at low to moderate levels but would fail when driven hard.
1helpful
Hello i have a yamaha RX-v459, and i have an HDTV, can i connect my cable box to the yamaha and the yamaha to the TV and get HD? the Yamaha does not say HDTV, does that matter, or will i still get HD?
I getting noise in yamaha rx-459 please help.
I used to get noise as well. It turned out to be that one of the cables to the speakers was loose. Try tightening the cable connections to the Yamaha and to the speakers.
1helpful
YAMAHA YDS-11 TO A RX-V459
Vocals missing while playing with 2 speakers
Go to the amp "Basic Setup" and alter basic setup according to
- the size of the room (details in the manual)
- alter the no. of channels e.g. if you have only 2 front speakers, change the channels to 2.1 (.1 for the subwoof)
- Once the setup is changed, the amp pumps in sound according to the set up
All the best
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
