SOURCE: nokia n70 reduced font size
http://m.psiloc.com/d/s60/Psiloc_FontMagnifier_S603rd.sisx
download this app this will increase ur font size
SOURCE: hii,m shilen ,how to change a font size in nokia
1. go to the menu.
2. and select setting and choose display setting.
3. and select font size and change size.
Thanks.
Aman
SOURCE: The SMS font size on my 1600 changed
I don't think there's font setting with your phone. Please reset the mobile to "Factory Restore" using the code 12345, to do this, go to settings - scroll down to the bottom and select "factory restore" open it and enter the code and press ok. This will reset you font size. But if there's a firmware problem, I can't ascertain you that this will work.
good luck.
Thanks for using FixYa.
Testimonial: "Fast and accurate response. Restore factory settings option did however cause me to temporarily lose predictive text function. A look at the on line Nokia 1600 user guide got it back for me however. Thanks a lot for the help!!!"
SOURCE: Hi,how can i change font ( big size )in Nokia N900
hello,please kindly move under your settings,you will then see display settings and click on font,there you can change it to whatever font you desire.
please kindly rate the solution if it's helpful,
take care.
SOURCE: how to change nokia e65 font size
The font size cannot be changed by using any option in mobile but there is a trick to do it .
The following link helps in increasing font size
http://www.dreamstrikes.com/nokia/510-nokia-e65-fonts-too-small-get-new-fonts.html
