Cars & Trucks Logo
N
Nico Fourie Posted on Aug 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Causes for high fuelcomsumption on a 1997/98 daewoo espero cd 2.0i
Why is my daewoo espero cd 2.0i heavy on fuel
Howard Pfeiffer
Level 3:
Genius:
  • Daewoo Master 1,249 Answers
  • Posted on Aug 14, 2015
Howard Pfeiffer
Daewoo Master
Level 3:
Genius:
Answers
1249
Questions
Helped
351271
Points
3712
A tune up of plugs wires, and air filter...also fuel injector cleaner...guessing well over 100,000 miles...
I can not find a fuel injector for my daewoo espero 1.8L. Can i buy a fuel injector of another car with a bigger engine??
Your injectors are sized for your vehicle. You might get lucky and the other one will fit. Check the part numbers on each and see it there is a match. The port size on the injector may be different coming from the other engine so you need to check. Too big and you will flood the cylinder with fuel and waste gas. Too small and you might not combust and misfire and get check engine lights. The injector o-ring may not seat properly and allow fuel to leak out potentially causing an engine fire. Best to match injectors. You could always go to a junk yard and pull an injector out of another matching engine.
My Daewoo espero is not starting The fuel is getting to the engine The starter is turning The battery is full. The distributor is fine What can the problem be?
Spray some carb cleaner into the throttle body and see if it cranks. It may be getting fuel pressure without a control signal commanding the injectors open.
How much should be the fuel consumption of Daewoo 93 in city
31.3 to 34.1 depending on model like for example racer,tico,or espero
Why my Daewoo Esparo doesn't start
Do you electrical power? Are the head lights working? Are they as bright as they should be? If not check the battery. If they are does the engine crank when you try to start it? If not check the starter. If it does try spraying some starter fluid on the air filter. Try and start it again. If it then runs and shuts down after a second or two you have a fuel issue. Is the check engine light on? If it is you may a sensor related issue causing the engine to not start.
1helpful
I ran my Daewoo espero out of petrol and now that i have put petrol in it it just wont start. no matter how much i try and jump start the bastard
When you turn the ignition to ON, you should hear the fuel pump hum for a couple of seconds. If you can't hear it, check the fuel pump fuse..... check all fuses anyway.
Dont know which one is number 1 spark plug daewoo espero cd 1995
the cylinder closest to the camshaft cover right side of vehicle
2helpful
Daewoo espero fuel injector
Try fuel injector cleaner. It is a solution/ solvent like that you pour into your fuel tank. It works perfectly well and great for cleaning that.
Good luck.
Rate this please.
2helpful
Only runs rough after running and fully warmed up
when it is cold there is extra fuel going to the plenum chamber its like pulling a choke on a carby that is why it is running smooth but when engine gets hot it is back to normal supply of fuel and yours is not normal.one reason might be not enough pressure in the fuel rail due to defective fuel pump or pressure regulator or blocked fuel filter. it is best to check your fuel pressure first.
2helpful
5answers
Daewoo Espero
Check the timing belt same same problem with mine
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
