Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
This means that the child lock (control lock) feature is active. There will be a button (or pair of buttons) depending on the model that you need to press and hold to toggle off the feature. If it is a single button, there will be a tiny padlock icon on the button. If you need to press and hold two buttons, the padlock symbol will be in a line indicating both buttons.
A likely combination is the Select and Option buttons. These should be held together for 10+ seconds. (This is the combination for some Affinity washers.)
If this doesn't work and you can't see a lock icon, please add a comment with the model number of your washer. I'll be glad to check what the combination is for your washer. The model number is usually on a plaque on the rim of the door for front loading washers or at the back at the top of the drum for a top loading washer.
I hope this helps.
Cindy Wells (the control lock prevents someone from accidentally changing the cycle or a child starting a wash cycle with the cat or another child in the unit)
You are putting too much soap before you begin the wash cycle...... When the word SUDS is displayed then on the rinse cycle there is too much soap and the suds are still on the clothes. Try cutting back on the soap, maybe cut back almost 1/2.
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
That symbol means that the dishwasher is heating the water, bringing it up to the required temperature to properly sanitize your dishes.
This symbol can appear during the wash and rinse cycles. It is nothing to worry about. Most dishwasher will heat up the wash and rinse water, it's just that Bosch decided to add an indicator, so users would know that any delay in the wash/rinse cycle, is a result of getting the water up to the proper temperature (typically around 140 degrees F)
Even if you've got your hot water heater or hot water supply set to a very low temperature, the dishwasher will use the built-in heating element (the drying element in the bottom of the dishwasher) to heat the water.
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Code rL or F34 --> Load detected in machine at the beginning of the clean cycle. Push stop, remove clothes from washer & try again. Mine did this to me, even though there was nothing in the washer. I just tried it a second time & all is good again.
