Only cold inlet
SOURCE: hot point aquarius 1100
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
SOURCE: Electrolux/Simpson EZI sensor 5.5 kg machine cycles.
Well I'm an idiot. They did say there was a fast wash, but it specified that it was for extra rinses to help people with detergent allergy etc., but did not give a time for the cycle. They should have said it was the short wash for everyone. I tried it, and it was fine. Thanks anyway. If I ever have a real problem, I'll be back.
SOURCE: We are using our Electrolux/Simpson Ezi Sensor washing
also have the same machine - if you wash with the eco rinse the clothes will ALWAYS have the soap residue on them and if you use the deep rinse then this machine will just sit there doing the very occasional agitate for up to 6 hours - can't win - have only just hung out a load and as usual there are many many dry spots on the sheets which is a daily occurence - really hate this machine and it's so called u-beaut functions -
SOURCE: I have a Samsung WA13G7Q1 washing machice The
the quection is not complete, when the cold water inlet and hot water inlet both work then what is the problem....
SOURCE: Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Hi
To solve the beeping and lid lock light flashing and the machine not doing a spin dry. Do the following.
I have a SIMPSON EZI SENSOR 8Kg top loader. This is what I did.
WARNING HIGH VOLTAGE. switch the power off and unplug the machine.
DO NOT do this if you are not familiar with working with high voltages.
To get access to the lid lock switch,
1. Remove 2 screws at the rear of the washer.
2. Remove 2 screws at the front of the machine located under the lid and covered by small round plastic plugs.
The top cover can now be raised gently from the front.
3. Remove the 2 screws that hold the lid switch.
4. Remove the clear plastic cover from the lid switch.
5. DANGER HIGH VOLTAGE ( Verify that power is off)
6. Find 2 blue wires these go to a magnetic reed switch (25mm long 3mm Diameter).
Cut
the blue wires and discard the reed switch. insulate the ends of the
blue wires and push them back into the track in different directions so
there is no possibility that they can make contact with each other.
7. Find 2 white wires these go to a set of contacts that are mechanically closed by the solenoid.
8. Pull out the contacts and the 2 white wires.
9.
Cut the white wires at the contacts, strip 5mm of plastic off the wires
and twist them together, The wires will have corrosion, clean them with
sand paper, they must make good contact. I recommend that you solder
them together.
10. Insulate them and push them back into the track.
11.Reassemble starting with fitting the clear plastic cover.
Your good to go BUT BUT BUT,
WARNING
The Lid safety protecting during the spin dry cycle will no longer function,
So don't do this if you need the safety of the lid closed during the spin cycle.
Remove 2 screws at the back of the machine
