Connected the wrong cable into the HDMI port in error and now the camcorder will not switch on and the battery won't charge at all. What could possibly be the fault? Trying to assess the damage and associated costs. Out of warranty.
In DCRTRV430 Camcorder, the C:31:42 error message is a Self diagnostic display. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camcorder. In C:31:42, the issue is with the tape and the tape mechanism.
I suggest that you remove and reinsert the tape to check if it helps. You may also try inserting new tapes in the Camcorder. Please remove the battery and/or power cable, connect, and perform operations from the beginning. You may also try resetting the Camcorder back to factory default after removing the tape.
To Reset the Camcorder, perform the steps below:
? Please open the LCD screen to locate the RESET button.
? To reset the Camcorder, press the RESET button using a sharp-pointed object.
? Please make sure that the Camcorder is turned on while pressing the reset button.
Also, try turning off the Camcorder and remove the battery pack. Then move the 'Power Switch' of the Camcorder to the ON position
for 1 minute. After about 1 minute, move the 'Power Switch' to the OFF position.
Now reinsert the battery, turn on the Camcorder and check whether it is working fine.
Thanks.
KenSolutions
FixYa
