If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
SOURCE: magnavox tv not responding to remotes
I came accross this question, because I've been looking for the remote code for my cable remote. I had originally put the TV remote somewhere in a box when I was moving years ago, Since my cable remote changes the channel, I've been doing the same as you all this time. Therefore, I totally understand your frustration on trying to understanding how to navigate within the menu: It's not what you would think would be a standard or logical way....
Anyway, in my research, I did come accross the TV manual, and I found the instruction on how to reset the TV. I tried the steps, and THEY"RE STILL confusing, so I've added my own hints....hope this helps:
Your TV can be reset to the factory settings in case you forget your Smart Lock password, or want to change the picture, sound, or features settings.
1 Press the MENU button on the remote control to see the onscreen menu.
In the left panel, you will see four icons (from top to bottom)
When the Menu screen is showing the left panel as highlighted light grey, the Chanel buttons have Page up/Page down Functionality
2 Press the the (CH UP) or_(CH DN) buttons to highlight the FEATURES menu.
Navigate to the FEAUTRES menu (icon of pliers and a hammer - bottom of left panel) and you should make sure it is highlighted in blue
3 Press the (VOL+) button to enter into the FEATURES menu.
The right panel should now be highlighted in a light grey
4 Press the (CH UP) or (CH DN) buttons to highlight the FACTORY SETTINGS control.
This will select items in the right panel, FACTORY SETTINGS in on the bottom
5 Press the the _(VOL+) or _(VOL-) buttons to reset the TV to the original factory settings.
6 Press the MENU button repeatedly to clear the menu from the screen.
The entire manual is found at this link: http://www.m4c.magnavox.com/files/1/15mf200v_37/15mf200v_37_dfu_aen.pdf
BTW, of any one know how I can program or get an RCN remote to use on this TV, please let me know!!!!
SOURCE: how do i get my toshiba regza lcd tv to work via
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
SOURCE: How do I unlock the 'panel lock' of my Toshiba
Hello Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
To unlock the panel lock of Toshiba TV, follow this.
