Amana SXD22S2W
refrigerators are made by Whirlpool and what you have happening is common with a
couple possibilities. Most likely the W10245167 Water Inlet Valve
is not shutting off after the fill time of about 7.5 seconds. If this is
happening the water will slowly fill the
ice maker tray above the lever that it should and causes the ice to connect together
on the top thus not allowing the cubes to be harvested because they are
basically welded together as a whole piece. And the other possibility is the
ice maker itself is needing an adjustment of the water flow time. Below I will
post a Icemaker
Repair video telling how to adjust the
time and other things to look for. This is possible but most times not always the case. Adjusting the flow time is
delicate and a little change can cause too much or not enough water. Lets watch
the icemaker a little closer and see if there is ice freezing up in the fill
tube behind the ice maker. You have seen the leaky faucets before and an old W10245167 Water Inlet Valve
can do just that making a mess inside your freezer and ice maker if
leaking. Here is a Whirlpool Ice Maker
Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat
Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should
you have any questions, Thanks Sea Breeze
D7824706Q Ice Maker Assembly
