It fills with water. Makes a loud screeching noise
Screeching noise is typical to drum's broken bearing issue.
See some infor about issue:
How to Diagnose Drum Problems in Washing Machine
How to change drum bearings on washing machine
How to Change the Bearings in LG Washing Machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Some more video there... explore
Now, if you don't find it so easy to replace those bearings or you are not sure if this is your problem, call a repair service
Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve.
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For
replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
