I want the sacnner to always on caps lock
That will probably only be adjusted in the actual barcode software that you are using within the mc9090 .. at the moment I am hundreds of miles away from my 9090..but if you still have not resolved this problem. Check to see what the name of the software thats actually turning on to decode the barcodes. It should have a setting...or let me know the name of the software and I'll do some research. I'm not an expert, but have fought with my 9090 for years. I've actually reached its data capabilities and have it sitting on the shelf as relic now
SOURCE: Motorola MC3090 do not read barcode starting with zero
look online there are learning barcodes out there you can scan, look for one with zero in front, if you are making the barcodes yourself than put a * at the beginning and end and then make barcode, it will capture everything in between,
