Washing Machines Logo
J
Johnny Dale Perkins Posted on Aug 18, 2015
Fiher&paykel when its running it says power out then starts up again durring the cycle ?
1 Related Answer
Anonymous
  • 351 Answers
  • Posted on Mar 02, 2008
SOURCE: Fiher and Paykel dishwasher
check the lid switch if it beeps fast.
Error code 42 on fiher and paykel top loader
42. (00101010) Phase 1 - Rotor Fault
Primary Source: The Motor Controller has had some confusing information feedback.
Action: Turn off SmartDrive at the wall and back on again after 5 seconds.
Restart.
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
3answers
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
2answers
Fishcer and Paykel Dishwaher is continually beeping but not starting the cycle. It has water in from previous part finished cycle when the beeping started
You have a leak. When the bottom sensor detects the wetness, it won't allow to start.
Pull out the tube put some small tower unser the tube to dry out water.
Unplag power cord for 24 hrs to let the sensor dry out.
Then you will be able to start.
However if you don't replace the lid seal the leak will happen everytime a cycle starts and you will have the same problem over and over again. Good luck to fix the lid seal.
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
1helpful
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
