A drawer on a CD player
Disc drawer will not open or close, but can hear the gear trying to do so.
    Champion:
  • 301 Answers
There is a little belt that goes bad in most cases. We have ton of them here at Paradyme Service but you have to bring the unit in we don't sell parts only. 916-971-3600 Sacramento Ca.
Posted on Aug 25, 2015
6ya staff
SOURCE:
How do I get the CD drawer to open?
Normally, there is a small hole located below the disc drawer that you can put a straightened paper-clip in to open the drawer.
Feb 02, 2015 | Audio Players & Recorders
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Dvd player won't stay open
It seems like the gear has skipped, you will no doubt have to take it apart and reset the gear to the proper position, There may be a "C" ring retaining the gear to the spindle, you should be able to remove it with a small screwdriver - you may want some safety glasses.
When taking it apart you may want to use some cardboard to press the screws into so you remember where they came from and don't lose any parts.
Usually there is a space in the gear that should be about 45 from the start of the gear at the closed position. You want to make sure in most cases that the tray is either in the fully open or fully closed position before attempting to reposition any gears.
I find it useful to take pictures of each step of the process so you know exactly where everything should be when you put it back together.
Hoped that helped. Good luck.
Dec 28, 2013 | Sony DVP-SR500H DVD Player
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
It doesnt recognise cds
There are a few possible causes. 1. Lens on laser pickups dirty. 2. The belt that closes the drawer also lifts the CD assembly to allow disc to spin. If the belt is loose, drawer may close but not be able to lift CD. Listen to mechanism after drawer closes. Do you hear the disc spinning up? or Do you hear a motor trying and then shutting off? You can also remove the case top and visually check these. 3. The spindle height may have slipped. 4. The focus and tracking may have changed with age. 5. The pickup may be bad. And finally the carriage may be stuck and not moving the Pickup(Laser Assembly) to its start position.
Jul 17, 2009 | JVC MX-D401T Shelf System
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
141 people viewed this question
Ekse
 Grubhead
Grubhead
