Sounds like the laser pickup unit has damaged. Replacing this part to Blu-ray players is a very skilled work. It will be best to contact any experienced service technician to replace and to align it.
SOURCE: No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
SOURCE: disc read error
Could be one of several things:
Hope that helps....
Geno
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
SOURCE: No Disk error message
The only reason why its giving you the error is because the player cannot read the DVD , the cause for that are the DVD is bad, so try a different DVD and check if it will play if it did play the first DVD is really bad, But if it still did not read a different DVD in means the lens of the player can be dirty or bad, try to run a CD cleaner to clean the lesn of the player if still the same the lens may need a replacemnet already..
Hope that helps..........
I was able to fix the problem by buying a disc lens cleaner at an electronics store and allowing it to "play" for 1-2 minutes. Was also told you could possibly clean the laser-reader with a cotton swab soaked with rubbing alcohol. Otherwise the laser-reader may be bad or out of alignment.
