Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here. The manual should have illustrations giving the locations of all buttons.
You can do this by: Check the oven display to see whether the
screen says "LOC." When "LOC" is displayed, the oven lock is activated
and the door cannot be opened. You need to make sure it is locked so you
do not mistakenly lock the door.
Press and hold the "Stop" button on the oven control panel
until "LOC" disappears from the display. Some oven models have a button
marked "Oven Lock," which should be used instead of the "Stop" button.
Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
The control is locked as what "LOC" indicates. Press the Options and Select buttons simultaneously for 10 seconds or until "LOC" is no longer displayed. Pressing the same buttons for 10 seconds will lock the control. There is actually a padlock sign marking between these buttons to indicate that these buttons are used for locking and unlocking the control.
The LOC is for the buttons, it's a safety feature. One of the buttons should say "lock" or something next to it in small text. Hold the button down until the indicator goes off. If this does not solve the problem how about a make and model or something to help us out??!!
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
seconds until ”LOC” is no longer displayed.
Today the "Loc" light came on and I can not use
the oven... the oven door does open and the
cook top works ok?
I see two others have the same problem.
I tried to un-plug the electric plug but this did
not re-set it?
This unit is about 7 years old. I can not find
the manual. There is no re-set button anywhere
and I also can not find a model number on back?
