SOURCE: transfer contact list from samsung cell phone to blue tooth in 2004 ls430 Lexus
There should be a tiny 1/4 inch square SD card inside the phone, usually inside or under the battery compartment.
Just transfer this card to the new phone.
This only works if you have put the contact list phone numbers ON the SD card and NOT on the phone memory.
SOURCE: SGH-A701 Mobile bluetooth
first of all you have to have you bluetooth visibility on for it to connect to another device.
Page 90 on your manual.
Now if you are connecting to a car in which you are, leave the bluetooth enabled on your phone. You should be just able to connect to your phone when you turn the device on in the car.
(your probably driving a toyota)
If its not automatically detecting it, your toyota is the problem. when you get in the car all you really should have to do is go to connectivity on your phone, bluetooth, connect to the device.
And the toyota is probably a prius!
My phone connects automatically every time i turn the phone on.
when you set up the device, it will ask you the question.....connect automatically>? so you need to answer yes.
Let me know if there is anything more I can do.
Clint
SOURCE: Phone memory protected
Under Menu>Contacts>Settings.... Under memory in use, change it to phone and SIM. It will probably ask for a security code which should be in your book, if you haven't changed it, its something like 0000 or 12345 or similar. then you should be able to copy all to the simcard.
Good Luck
[email protected]
SOURCE: blank screen on kyocera cell phone
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back.
Thanks mymomcallsme
