http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Oldsmobile Temperature Gauge Lamp Switch?
http://technoanswers.blogspot.in/2012/02/dodge-neon-gauges-not-working.html
http://schematicsdiagram.blogspot.com/2011/12/temperature-gauge-went-up.html
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
http://technoanswers.blogspot.in/2012/02/how-to-remove-instrument-panel-on.html
If
all voltages checked ok, then most probably its faulty instrument cluster board
on which gauges are connected. Yes if cluster circuit board looks ok, then also
it can be faulty. Somewhere there is minute short or burn on board then such
problem arises.
Also
check the fuse box. One under hood and other under dash.
Inspect
each and every fuse and see if all are fine or not.
For
more troubleshooting on these cluster gauges I suggest you to refer the list of
help links mentioned below. Its step by step instructions will help you to
confirm the exact cause of problem in these conditions: ---------
Click
the link below: ------
2004 Toyota Tundra:
Oil Gauge and Temp Gauge Not Working?
http://howtobyme.blogspot.in/2012/05/2004-toyota-tundra-oil-gauge-and-temp.html
2005 Lexus SC430: Fuel Door, Dome light and Fuel Gauge Fuse
Location?
http://howtobyme.blogspot.in/2012/05/2005-lexus-sc430-fuel-door-will-not.html
Toyota 4Runner:
Temperature Gauge Sensor
http://technoanswers.blogspot.in/2012/04/toyota-4runner-temperature-gauge-sensor.html
Temperature gauge sits over half way mark?
http://schematicsdiagram.blogspot.in/2012/04/temperature-gauge-sits-over-half-way.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Temperature gauge does not move and no heat when heater is
ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
2003 Pontiac
Grand Prix: Erratic Fuel Gauge?
http://technoanswers.blogspot.in/2012/06/2003-pontiac-grand-prix-erratic-fuel.html
Temperature gauge keeps fluctuating up and down close to
red?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-keeps-fluctuating-up.html
Temperature gauge on the dash quit working on Pontiac Grand
Prix?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html
Fuel gauge jumps from empty to full?
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
• Oldsmobile
Fuel gauge drops to Empty?
http://technoanswers.blogspot.com/2012/01/fuel-gauge-drops-to-empty.html
Dodge neon gauges not working?
Temperature gauge went up?
Temperature gauge stays At cold on jaguar?
http://technoanswers.blogspot.in/2012/02/temperature-gauge-stays-at-cold-on.html
How to replace Instrument panel and dashboard on Toyota
car?
How to remove instrument panel on Chevrolet car?
How to remove control panel on Buick regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-control-panel-on-buick.html
These
details will help.
Thanks.
Hope these helps .
