2 pin socket (magnetic - sine wave output). One pin is 'ground' the other is
'signal'. A voltmeter set to 2 volts AC (note) should measure a signal in the 0.2 to 2 volts range on the 'signal' pin.
pin socket (Hall effect, magneto - square wave form output). One pin is 'reference' (5volts), one pin is
'ground' and the third pin is 'signal'.
A DC (note) voltage should be detectable in the 0.5 to 1.5 volt range from the
'signal' pin.
It is important that the voltage measurement
take place at start up when the engine is cold and again, 20 minutes later,
when the engine has fully warmed up to operating temperature.
These devices do not often fail and are expensive if purchased from the the Mercedes dealership, shop around on-line or try a breakers yard.
