Tablets & eReaders Logo
David Allen Dismond Posted on Aug 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I unlock the home screen of my disabled iPad mini?
Kolbrun Gunnarsdottir
Level 3:
  • Master 1,228 Answers
  • Posted on Apr 14, 2016
Master
Level 3:
Answers
1228
Questions
6
Helped
277612
Points
3915
Good evening to you
If I remember correctly I held in the home button and sleep button simultaneously for ca 30 seconds. enjoy your coffee, Kolbrun
1 Related Answer
A
Anonymous
  • Posted on Mar 22, 2013
SOURCE: My ipad mini keeps shutting off
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
My IPad mini is showing info when I open it -disabled try again in 60 minutes, how do I fix it
you need to connect your iPad to a computer that has iTunes then hard reset it by pushing the sleep /wake and home button till you see the iTunes logo on your phone, then you'll see and option on the computer screen to restore, then click restore then wait for it to finish, then you can setup your device like new
Forgot passcode for your iPhone iPad or iPod touch or your device is...
2answers
2helpful
4answers
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
iPad Air
iPad mini/iPad pro
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
How do i restore my password disabled ipad?
You can enter the recovery mode in iTunes and restore password on your disabled iPad. Just follow below steps to do that.
iPad Air
iPad mini/iPad pro
restoring-ipad-software-2ka233npl0212ndjbhnpio3z-3-0.png For more methods, check: How to Unlock iPad?
IPad mini is disabled cant unlock screen.
just says I pad is disabled and off it goes
2answers
Disabled ipad 3
What wrong with your iPad 3? Maybe you can reply on the tablet replacement repair parts for iPad 3 to make your iPad return back new and health. Nowdays, there are more repair parts for fixing the unflexible and scracked.
4helpful
3answers
My ipad is disabled how do i fix it
Try connecting it to iTunes, turning off the ipad, then hold both the lock and the home button for 10 seconds, then relese the lock button while continuing to hold the home button until iTunes recognizes the iPad. Then you should be able to reset it without problem.
Top iPad mini Tablets & eReaders Experts
ADMIN Eric
ADMIN Eric
NOEL
NOEL
john h
Are you an iPad mini Tablet and eReader Expert? Answer questions, earn points and help others
