Question about Canon Powershot A2200 14.1mp Digital Camera red
Viewfinder is black, don't see what I am trying to take a picture of
Everything seems to be working okay, but I cannot see anything through the frame in order to take the picture.
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 2985 Answers
SOURCE: IXUS 75 has blank LCD screen
A screen fails in one of two ways. 1.Backlight goes- If looked at closely or to one side the images are there as ghosts but not illuminiated. 2. Connector or board component has failed which could mean with a back light Okay a brilliant white screen. Failure 1 - nothing for you to do there Failure two -if it is a connector- gently flexing the camera casing in the region of the base of the screen may elicit a reconnect. In either case however- I think you will find that unless it is under warranty or insured in some way- New camera will be a more economical approach. But check out makers support site first.
Posted on Aug 18, 2007
Anonymous
  • 6 Answers
SOURCE: My canon rebel xti is broken?
This will happen if you have the camera set to manual and the aperture/shutter speed combination does not let in enough light. There's a wheel on the top of the camera with M, A, S, P, Auto settings - turn the wheel to select P or Auto and try again.
Also, if you're indoors, you may have to use the flash.
Posted on Mar 19, 2009
t00nz
CameraR
  • 4738 Answers
SOURCE: Everything appears to be working on my camera
If your camera is an SX110 IS, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
However, if you made a typo, and your camera is really an SD110, the problem would then likely be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Posted on Feb 17, 2010
omtronixom
om sharma
  • 172 Answers
SOURCE: Viewfinder is blank, but the camera works normally.
Iris or Aperture not working its all time off so that you can not see through camera.You need to change Iris cable.
Posted on Mar 31, 2010
Remote control for Smart Parts 11" digital frame (SKU SP11008) doesn't work. Have changed battery, but cannot get any type of connection between remote and frame. Received as gift over a year ago, but did...
We have to check the remote control first. After that check the digital picture frame.
Follow the instructions below please;
We must be sure the remote control is working;For this control:
1. Take a digital photo of this remote control while pressing the remote control button.
2. If it is working then the picture must shows the led lamp of remote control as firing.
3. If the picture does not show that it is firing, then, you should control batteries of the remote control.
4.Check the battery and the battery polarity of the remote control.
5.If it is firing. You should control Digital Picture Frame.
6. If the battery of the digital picture frame does have enough energy or not. If battery is low then you shoud use it from the closer distance.
7. I do not think that the Digital Picture Frame is out of order.
Regards.
Apr 21, 2010 | Smart Parts Digital Picture Frame
HOW DO YOU GET PICTURES TO SHOW IN THE ORDER THEY WERE RECORDED
Make sure that you have the latest firmware version. Get the latest at www.kodak.com/go/downloads. Also, you may rename the picture files like 001.jpg, 002.jpg so on and so forth.
Aug 14, 2009 | Kodak EasyShare SV811 (8858946) Digital...
When I plug my SV811 into my pc using the USB cable, nothing happens, my computer does not seem to reconize it. Is there anything I can do?
You need to use the CD which came with your camera and install the drivers for your camera. The drivers are needed to in order to connect to your pc. If you do not have the CD, you should go to the web site of the manufacturer and download the drivers for your camera and install it. After you install the drivers, your camera show up when you connect it to your PC
Good Luck!!!!
Jun 09, 2009 | Kodak EasyShare SV811 (8858946) Digital...
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Pandigital Frame Photos NOT in order or NOT in sequence..FIXABLE?
i'm having the same problem. I've gotten a good amount of photos going in the timeline order but then it starts messing up again to where it's not in order! GAH i thought i had it! :(
Jan 10, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Polaroid Digital Frame Model XSA-01140B freezes up
I was using an 8G flash drive and had over 6G saved to it. I decided that maybe the frame could not handle that many G's so I deleted everything but 2G and it WORKS!!!!! Maybe anything over 2G is too much for it to handle. Try it and let me know. I am interested if this solves everyones problems.
Dec 19, 2008 | Polaroid IDF-1030 (826219006783) Digital...
SEQUENCING PICTURES IN BUILT-IN MEMORY
The DPF-80 has now way to sequence pics. The only way for them to play in an order is add them one at a time to the frame via the computer. The files can not be batch sent, such as sending a whole folder at one time. Windows will dictate the order in which they are transfered if you do it that way. Transfer one pic at a time. Tedious, but it works
Dec 05, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Canon Powershot A2200 14.1mp Digital Camera red Logo
59 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
