Re: Everytime I use my tablet it shuts down and I have to...
The battery must be connected loosely to your tablet due to which there is a disconnection in the power supply to the circuitry and hence it gets shut down.
I feel this could be one of the many of the reasons for shut down.
Here are two things to try: I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Depending on why your tablet is frozen, pressing the "Power" button -- sometimes called the "Sleep/Wake" button -- might turn it off. Some tablets give you the option to restart or shut down; if you have this choice, pick the option to shut down the tablet completely. If pressing the button once doesn't do the trick, hold it down for 15 to 20 seconds -- this often forces the tablet into shut-down mode.
Press the Power button longer until your tablet shuts down. If you can restart it, find a cache cleaner software to clear the cache for more space. Sometimes, the cache takes up nearly all the available space from the tablet's ROM. This slows down the tablet considerably and also causes malfunctioning of the OS.
1)Make sure the tablet is NOT connected to the charger 2) Power off the tablet by holding down the power button for about 10 seconds 3) Once it is off, hold down the HOME button and connect the charger while the button's being held down. 4) When you see the HKC logo come up, let go of the HOME button. 5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5. 6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again. 7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button. 8) Navigate to "Yes - delete all user data" and select it. 9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
Press and hold your power button for 20 seconds to perform a soft reset and then turn back on like normal. This will not erase any data from your device like a hard reset will.
ALL CREDIT OF THIS GOES TO HKC...
this 100% works to factory reset if you are locked out of a hkc p886a tablet...
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
So you need to be In the main menu interface then press the power button for about 5 seconds to shut it down. Below is the power section out of the manual.
1.2 POWER
startup: Long Press and hold the power button, the system will enter the main interface
shutdown: In the main menu interface, Press the power button about 5 second to shutdown, The system can hint "power off" option, Clike"ok". you can safely shut down.
Lock screen: Short press Power button to lock screen or unlock screen.
Remark 1.When power is empty,system will shut down automatically.
2.Illegal turn off the device,restart will scan and restore the disk,it may take longer time to enter into system
